106 gti major problems any1 help????ngcw84 02-16-2005, 04:56 PM Hi there as u av seen i have several pugs, the newest addition is a y plate 106 gti. i thought i got a great buy but have several problems. any1 have problems with there battery light flickering at about 4 thousand revs and over?? alternator is fine does any1 think it could be a dodgy earth?? also went to put new speakers in the front and rear of car. the front speakers are rivited on and rear guards wont cum off so i av to take the entire rear piece of to get too. also ma sterio looses power everytime i turn my ignition off and it resets the memory in it and the clock resets. can any1 help me wiv any of this i would be very greatful many thanks nick Mr Vegas 02-16-2005, 11:36 PM Hi,the stereo fault will either be the head unit faulty or there will be no 12 volt constant feed to the unit.Remove the radio and probe the wires making sure it has the required voltage. For the battery light flickering it sounds like it's a loose connection at the alternator,i'd check the wire connections...the fact that the light comes on after 4000rpm's indicates that one of the terminals is loose.(how did you test the alternator?)have a play around with all the terminals while someone checks the dash to check for the apperance of the light. As for the speakers can't you just drill out the old rivets? ngcw84 02-18-2005, 03:20 PM hi there i did just dill the rivits out they were easy. jst thought it was a bit weird to mount speakers. i tried the terminals and all the earthin points in car same problem. The battery is chargin as when i put the multimeter across the battery. This is a very weird problem its booked into peugeot on monday. ANy idea if it cld be the belt at all?? Mr Vegas 02-19-2005, 04:13 AM the single wire to the alternator will be the wire causing the light to come on....could only be the belt if it's really loose not allowing the alternator to charge enough...did you put the multimeter over the battery while reving engine and under load etc? ngcw84 02-19-2005, 07:48 PM hi there cheers that worked a treat wiv the wire!! when i lock the car the alarm keeps goin off any chance u now why that is?? its the normal factory alarm?? cheers nick Automotive Network, Inc., Copyright ©2012
