How 2 open hoodQuestionmark 02-16-2005, 03:48 PM How do you open the hood latchj w/o the cable assembly inside the van? A. Souphound 02-16-2005, 05:40 PM How do you open the hood latchj w/o the cable assembly inside the van? If the cable is broken, maybe you can fish the cable out through the grill and un-latch the hood. Questionmark 02-16-2005, 06:48 PM If the cable is broken, maybe you can fish the cable out through the grill and un-latch the hood. That would be great "but" the cable is not there at all. What I need is how to open the latch from the outside! Argh! :) Then I can repair the @(*$$&(# thing! :) A. Souphound 02-16-2005, 07:52 PM That would be great "but" the cable is not there at all. What I need is how to open the latch from the outside! Argh! :) Then I can repair the @(*$$&(# thing! :) Evidently the cable has broken at the latch mechanism....The cable is normally attached to a lever on the latch. If you can't get your hand through the grill: You will have to use something strong like a piece of coat hanger wire to form a loop and snag the lever pulling it back toward the L/H front wheel (driver's side). to unlatch. When it is unlatched, you will still have to trip the safety catch to open the hood. Questionmark 02-16-2005, 09:11 PM Evidently the cable has broken at the latch mechanism....The cable is normally attached to a lever on the latch. If you can't get your hand through the grill: You will have to use something strong like a piece of coat hanger wire to form a loop and snag the lever pulling it back toward the L/H front wheel (driver's side). to unlatch. When it is unlatched, you will still have to trip the safety catch to open the hood. That sounds like a GREAT plan Thanks... I'll let ya know how I did!!! :) Automotive Network, Inc., Copyright ©2012
