Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Volkswagen > Jetta/Vento/Bora > '91 - '96
Old 02-16-2005, 04:53 AM   #1
dubjetta95
dubjetta95 Normal reputation
Water pump leaking, easy job to replace?
I found that my slow coolant leak is coming from my water pump. My motor is a 2.0 and I noticed that the water pump doesn't run off the timing belt like every other car I've owned. How hard of a job is this to do? I know I have to remove the plastic under panel, but is there enough clearance to slide the water pump out easily? If someone could tell me about their experience changing their water pump and tell me if it gave them a hard time or not I would greatly appreciate it. Thanks a lot!
dubjetta95 is offline   Reply With Quote
Old 02-16-2005, 05:03 PM   #2
boschmann
boschmann Normal reputation
Re: Water pump leaking, easy job to replace?
The timing belt has to come off.
boschmann is offline   Reply With Quote
Old 02-16-2005, 07:10 PM   #3
dubjetta95
damn, that really sucks. how come it looks like is has its own seperate belt then? how hard of a job is it?
Old 02-16-2005, 07:11 PM   #4
dubjetta95
<-- Me
Old 02-17-2005, 08:41 PM   #5
boschmann
It's just been that way since the 70's. It's not too hard if you're familiar with doing t-belts. Flywheel marks are a bit vague, get a manual.
Old 02-18-2005, 09:24 PM   #6
dubjetta95
so the water pump runs off of two belts?
Old 02-19-2005, 09:11 PM   #7
irbf
irbf Normal reputation
Re: Re: Water pump leaking, easy job to replace?
It looks to me that the pump runs off of a normal belt, not the timing belt. The pump is unusual (relatively speaking) and you can apparently purchase the "guts" to go into the housing or the entire think. Should not be more of a pain in the butt than usual...just messy...
irbf is offline   Reply With Quote
Old 02-20-2005, 04:56 AM   #8
dubjetta95
thats what i thought. thanks
Old 03-09-2005, 05:20 PM   #9
Boost192
Boost192 Normal reputation
the t-belt has to come off and you should change it regardless cause if your doing the water pump why do a job twice when you can knock 2 birds out with 1 stone
Boost192 is offline   Reply With Quote
Old 09-08-2005, 04:24 AM   #10
jimgiggles
jimgiggles Normal reputation
I just did the water pump the other day as well, taking the hard road (as usual). However i did find out from the local VW dealer that they replace the whole water pump and housing when they do the change, it seems like a bit of a pain though. Generally if your waterpump is dying, you may as well go ahead and change the t belt. I had to buy my water pump aftermarket because the dealer didn't sell the pump only. However, the timing may be a bit of a challenge if you don't mark your spots. And yes, there is a seperate belt for it.
jimgiggles is offline   Reply With Quote
Old 09-14-2005, 02:03 PM   #11
IowaHawkeye24
IowaHawkeye24 Normal reputation
If you can't do it yourself it ends up costing bout 500 I just had to have mine done a week ago
IowaHawkeye24 is offline   Reply With Quote
Old 09-16-2005, 10:37 PM   #12
veedubmechanic
VDUBMAN
veedubmechanic's Avatar
veedubmechanic Normal reputation
the water pump on a 95 jetta runs off a serpentine belt not the t-belt.
They are not too difficult, takes about 2hrs at home.
ASE and VW certified. Just here to help
all check light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
veedubmechanic is offline   Reply With Quote
Bookmarks
Google
Web AF
