Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Pontiac > Grand AM
Old 02-15-2005, 06:45 PM   #1
kingpinn
kingpinn's Avatar
kingpinn 0
spark plugs
1992 grand am 2.3l how do i change the spark plugs no wires what do i do im lost?
thanks
kingpinn is offline   Reply With Quote
Old 02-15-2005, 06:58 PM   #2
GTP Dad
Pontiac Guy
GTP Dad Normal reputation
Re: spark plugs
Remove the cover over the center of the engine. There should be 4 bolts. The plug wires are attached to the cover along with the coil. Remove it and the plugs are between the cams in the center of the engine.
GTP Dad is offline   Reply With Quote
Old 02-15-2005, 07:33 PM   #3
Ridenour
GranddAmnit
Ridenour's Avatar
Ridenour Normal reputation
Send a message via MSN to Ridenour
Re: spark plugs
Ah yes... the beloved Integrated Direct Ignition... gotta love it.
Even though GTPdad told you everything you need to know, I thought I'd throw in - as long as you have the IDI off, it might not be a bad idea to check the coil packs. Some quad 4 models are notorious for leaking coil pack housings, and they can get water in there and cause trouble. Just look at all 4 clear coil pack cases and make sure there's no sign of leakage or condensation.
Ridenour is offline   Reply With Quote
Bookmarks
Google
Web AF
