engine stall problem
drockg20
06-29-2001, 01:36 AM
My car has been stalling the past few days waht could be that cause? I have a 1994 P10. i have change oil. i have changed plugs, wires, cap, and rotor alrady. Also cleaned throtle body out and also EGR fittting. Help !!!!!!!!!!!!!!! Has anyone else has this problem. Also car is neutral or park and car is reving up and down by it self. Help !!!!!!!!!!!!!!!! Has anyone had this problem
poppy_morenito
06-29-2001, 06:39 PM
Hey D,
Call Andreas ....305 282 3643.... We are all getting together tonight for the South Florida Nissan Fast and the Furious screening....
Or drive down Sat. and hook up with him
FlossinPrimera
06-30-2001, 02:23 AM
I have had a similar experience with my 94 also (manual Trans). It usually occurs until the engine engine is warmed up then goes away. It could be the temp sensor.
GOKOOL
06-30-2001, 02:50 PM
the problem may be a vacume leak somewhere, or maybe the idle sensor under the throttle body is dirty or loose......for sure its gotta be a vacume leak somewhere.....check it out
GtRider
10-24-2001, 12:36 AM
hey drockg20 did you ever find out what was causing your engine to stall
P10DET
10-24-2001, 01:16 AM
I also vote for the vacuum leak.
When I installed the built NA engine in my SE-R it did some wild hunting for idle. It was a huge vacuum leak.
What happens in that case is the ECU is reading sensors that give it conflicting information so it searches for a smooth idle and of course, never finds one.
pearl-p10
10-24-2001, 11:10 AM
Try unplugging/replugging your mass airflow sensor. Then give your egr hose a couple of good wacks. My car does this like once a year and this seems to fix the problem. It may be worth a try before you shell out a couple of hundred bucks.
