Re: antoher tire question
I've got an offroad book with a table of what tires will fit what. According to it, you can fit 31x10.5 stock, 33x12.5 with a 4" suspension lift. I think it probably has to be suspension to get the frame out of the way. Not too sure on the newer ones, but my 86 comes pretty close to the frame.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
'86 3/4 ton Silverado
350 V8, 4x4, 4" lift, 1 ton axles swapped, converted to 4 wheel disc
35" BFG Mud Terrain T/As
Shortened to 109.5" wheelbase for those tight trails
http://www.boycottpepsico.com/default.aspx
You see "Fresh oil, loose gravel"; I see "Free undercoating"
