96 Dodge Caravan - No Reverse
1DrkAngel
02-14-2005, 11:11 PM
Have a 1996 Dodge Caravan 3.0 V6 for whatever reason the tranny will not go in reverse or should I stay in reverse. Wanted to see if anyone else has had this problem and haven't gotten it look at just yet, trying to find info of what I maybe in for.
theFREAKnasty82
02-15-2005, 01:55 AM
#1 thing to check for, make sure that your fluid level is at the right marks on the dipstick and also the color is not brown or black.
mrrob
02-28-2005, 01:31 AM
If you pull the pan, you might find a broken piece of metal stuck to the magnet, if your lucky, the band spacer has broken, I was lucky enough to just install a new plate (small rectangular plate) and re-tighten the band.
Good Luck
Mr.Rob
rebuilder
03-31-2005, 01:34 PM
does it jump out of gear when you push the gas pedal?does it go out of gear when you are on an incline.If #1 you have a 3pd trans with seized shift tubes,if #2 you have a vehicle with low fluid
