Code 9??
Google
Web AF
crX-RATED
03-18-2002, 03:39 PM
My check engine light came on the other night. The ecu is telling me code 9. That should be the #1 cylinder position sensor, right?? Well, i took off the dist. cap to check it out and nothing seems loose or wrong. My redline hasn't gone down like it should when the check engine light comes on, so i'm kinda stumped. Anybody else have problems with that sensor that can help me out??
Oh ya, i have a B16 motor, if that helps.
90CRXZCSi
03-19-2002, 12:55 AM
Well if you have a B16 then you obviously dont have the PM6 ecu so the codes are probably different. Look around to see if you can find the ECU codes for a B16 because the problem is most likely going to be different.;)
Marc-OS
03-19-2002, 01:40 AM
Try asking in the Technical forum.
Google
Web AF
