replacing bulb
on the backside of the headlamp assemblry , you need to 1st unplug the wires, then remove rubber grommet by pulling strait back, the unlatch the metal retainer. then slide our light bulb. ... do not remove the 2 top and 2 bottom clips on the front end of light. you do not have to remove either light assembly to change bulb, but you will have to remove the battery to change the left side.
hope this helps
