Re: Turning over problem!!!!
what do you mean the 700r4 was acting up? how do you know the transmission was acting up?
did you try to rotate the engine both ways or just one way? take the spark plugs out and try to rotate it. the compression will make it more difficult. if your bodyweight won't rotate it and you start bending the crowbar, then you have internal engine problems. do you have a warranty?
you need to be more desciptive. what is "acting up?"
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
