yet another blower motor/resistor question...
martinaggie01
02-12-2005, 10:15 PM
Anyone know the specific part number for a new blower motor for a 98 malibu?
Also, anyone know specifically where the ABS sensor is loctaed? Just had some brake work done, questionable, but I figured at 103k miles they needed replacing anyway (calipers, pads, etc.) the ABS light is still on, been on for awhile...will finding it and cleaning it work?
If it requires changing the whole hub assembly, I'm not even going to fool with it.
Also, really dumb question, but how do I remove the rear bumper? someone left a nice dent it it the other day while I was in HEB, and I can't seem to find the screws to remove it to knock it out.
BeatnikTermite
02-14-2005, 09:01 AM
If you have a CarQuest nearby, check out this thread:
http://www.automotiveforums.com/vbulletin/showthread.php?t=324040
Dawnna
02-14-2005, 07:43 PM
Having the same problem. Yup, a one piece unit, the ABS speed sensor is located within the bearing/hub assembly and after caliper, rotors, pads, abs sensor re-wiring, pump replacement on our 98, the abs light is still on! Now for the hub, damn, should have started there in the first place!
