Yeah, OK. You do realize what kind of job that is don't you?
Mounts: The mounts won't match up, that's for sure. And you might have problems such as having to relocate something in order to have proper mounting for your 6.
Exaust: Now you obviously are going to use the factory manifold or header and I'm not sure how high or low your pipe will come down at the front of the car. If it is exactly the same height, then it's fine. If not you'll have a hard time.
Tranny: You should measure how much distance there is between the shifer hook up to the tranny and the shifter itself. If it's different, you'll have to cut your floor. UNLESS... the Maxima is a cable shifter, but I doubt it.
Suggestion: The best way to do the swap is to install the engine temporarly and make the adjustments necessary then to take the engine out and paint your car. That way, you don't care about minor cratches as you setting the engine into place, AND... you get to paint the engine bay at the same time.
Wiring: Yes, you will need the Maxima computer, and maybe the gauges because of the wiring of the spedometer, lights, etc.
Oh yeah, check if the axels will fit off the Stanza. I doubt it. You will probably have to go with Maxima 'cause of the size of the wheel bearings. If the Maxima has 5 lug then you will have to go with the Maxima brakes and different wheels for the front.
Big job anyway.
Why don't you just go with the Japaneese SR20DET from the Sentra SE-R. 230 hp Turbo. Easier maybe. They have a very similar engine in the Jap Stanza (Bluebird) so every thing is a bolt in. The turbo also. Yes Bluebirds are turbo.
Some people are alive simply because it is illegal to kill them.
