Which Pistons?
Google
Web AF
NANOO
02-12-2005, 12:29 AM
Are there any stock pistons I can use in a b18a block to increase my compression?? If so which engines do these come in?
Thanks
civickiller
02-12-2005, 03:45 AM
b16 pistons
NANOO
02-12-2005, 10:42 AM
does it matter what generation B16 it is? What kind of increase will it have?
Thanks
NANOO
02-12-2005, 11:01 AM
b16 pistons
Will I need the rods too or just the pistons. I found a 1st gen B16 bottom end will that be any good to me??
Thanks
NANOO
02-12-2005, 11:15 AM
Found these as well!!
1 - ""4 - b16a second gen rods w/p30 pistons""
2 - ""1 - Set of mint shape JDM GSR pistons less than 15k on them""
Will these be any good?
Sorry for all the posts!!
95whitehb
02-14-2005, 07:33 PM
use 16a pistons from (4th or 5th gen. maybe ??? not sure) the b16 pistons are domed more than the GSR and will raise u (up to) a point....
u dont need tha b16 rods. but if u plan on gettin rods... get carillo, scat <(spelling?), or eagle
Medabots
02-14-2005, 10:09 PM
I dont know if these will help, but I had the same problem deciding which pistons to use and this is what I know:
lsvtec with b16 head and ctr pistons
head Gasket 2.8cc big vol= 497.6cc
piston dome vol. 6.3cc small vol= 39.2cc stock lsvtec=12.7
camber vol. 44cc
deck height .25mm 1.3cc
cyl vol. 458.4cc
in case you have a GSR head take a look at this :
lsvtec with gsr head and ctr pistons
head Gasket 2.8cc big vol= 495.6cc
piston dome vol. 6.3cc small vol= 37.2cc stock gsr/lsvtec=13.3
camber vol. 42cc
cyl vol. 458.4cc
Get the Civic type R pistons (CTR) and you'll be all set...
S13wanabe
02-17-2005, 01:10 PM
Generally you don't want to go above 11.5:1 compression on a street car on pump gas.
Kven
02-17-2005, 01:45 PM
B16a rods wont work in a b18 block(theyre too short). if you want the highest compression you can get, just get B16A pistons or the CTR ones. they pretty much have the highest domes.
Medabots
02-17-2005, 03:49 PM
can you use B16a or CTR pistons wihtout having a Vtec head?
whtteg
02-17-2005, 03:54 PM
Yes, they will be fine.
Google
Web AF
