Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chrysler > Cirrus
Old 02-10-2005, 09:36 PM   #1
TAGMXL
TAGMXL Normal reputation
Send a message via Yahoo to TAGMXL
Unhappy Cirrus Lx 95 Die For No Reason
CIRRUS LX 95 DIE FOR NO REASON.
I have made the key process and the code that showns is the # 12
the battery has been disconected in the prior 50 key start ??????
But really the problem it's that the motor stop working and the check engine goes on. I close the switch and when I try to restart the motor the check engine light, cruise light, temp light does not come on.
There's no spark in the cables and there's no gas in the line
So it's uses less to try to start the motor. All the system work only the motor don't start.
After 10-60 minutes all the indicators lights that I mentioned "check engine light, cruise light, temp light Now come on; then is when I can restart the car.
Any clues?
TAGMXL is offline   Reply With Quote
Old 02-11-2005, 05:48 AM   #2
theFREAKnasty82
theFREAKnasty82's Avatar
theFREAKnasty82 Normal reputation
Re: Cirrus Lx 95 Die For No Reason
You could have a communication problem between the Body Control Module, which controls your instrument gauges, and the Powertrain Control Module, which controls the engine and related functions. Your Powertrain Control Module is mounted on the driver's side fender by the shock tower; check the connections there to see if there's a loose connection.
theFREAKnasty82 is offline   Reply With Quote
Old 03-08-2005, 08:51 PM   #3
TAGMXL
Thank You Very Much
Old 03-08-2005, 08:57 PM   #4
TAGMXL
I bought the ECM from a wrecker as far us I found the Cirrus LX 95 ECM 4606064 it's the most difficult to find.
So far I have been installed the used ECM and the car runs better. I made the key dance and the only code that shows is 12 "battery disconnected" and 24 " TPC " related but the car still running.
Bookmarks
Google
Web AF
