Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Intrepid
Old 03-17-2002, 09:44 PM   #1
mo_99
mo_99
Unhappy Stalls
Since I was told that my 94 LHS is the sister car to the Intrepid, I thought I would post here as well as under Chrysler. I hope that's okay.
Here is my problem: At crusing speed my 94 LHS will drop to 200 rpms, sometimes recovering after a few seconds & other times it stalls. This usually happens within the first 10 miles of a 35 mile commute to work. When I brought it in to the dealer, there were no codes in the computer & of course they couldn't duplicate the problem. This has been occurring quite often for months but seems to be getting worse in the last 2 weeks with stalls happening about 75% of the time. (It used to recover most of the time) Any ideas? I'm about at my whits end.....
Has anyone out there had a similar experience?
mo_99 is offline   Reply With Quote
Old 03-18-2002, 03:11 AM   #2
Polygon
The Red Baron
Polygon's Avatar
Polygon +250Polygon +250Polygon +250
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
I have heard of other cars having this problem, it could be the throttle position sensor or there is a computer chip that is on the fritz. Just take it to the dealership and they will be able to tell you what is up.
Polygon is offline   Reply With Quote
Old 07-13-2002, 10:07 PM   #3
Intrepid es 3.2
Intrepid es 3.2
This might be the problem
ok i have a 98 intrepid and it stalled twice before the dam dodge dealer fixed it what it was was a defective wire harness that had some fraied wires and what would happen is the car would go crazy and die and would not turn over the first time what happened the pcm sensor blew they fixed it ..but not fixing the cause the 2nd time the sensor blew again this time they took apart the engine the top black part and found the wires were rubbing up against metal causing a short and blowing the sensor they replaced the wire harness and put in a second sensor ..so you might also have some exposed wires and are rubbing as you drive the wires shift so it might go away and then come back ..i'm pretty sure this is what is going on w/ your car have them check the bulletins also..
Intrepid es 3.2 is offline   Reply With Quote
Old 03-25-2003, 06:28 AM   #4
badassgremlin
badassgremlin 0
Send a message via AIM to badassgremlin Send a message via Yahoo to badassgremlin
yeah i used to have a 95 concord it had a miss in it i tried everything including using an anlylyzer still said everything was fine so i sold it:monkeypis ----concorde
after a long hiatus, ive returned! sold my srt-4 and am selling the 300m special!
badassgremlin is offline   Reply With Quote
Old 12-10-2003, 10:50 AM   #5
intrepid3.3
intrepid3.3 Normal reputation
Cool stalls....
Hey mo 99,
i hear ya, i have a '95 intrepid es 3.3L doing some of the same things...one thing i did was replace the oxygen sensors. It did help, controlling the fuel to the injectors, but the problem is coming back. Next to do is probably look at the spark plugs, or the throttle postition sensor. I'm having it checked out tomorrow. I'll let u know...
hopefully this cures it....
intrepid3.3 is offline   Reply With Quote
Old 02-03-2004, 09:01 AM   #6
sheldonbailey
sheldonbailey's Avatar
sheldonbailey Normal reputation
Re: Stalls
I am also having the same problem on my '95 intrepid 3.3L, I took it in and they explained that it was a vacum leak, check some of the hoses and found one cracked, I thought "problem solved" not a chance, so I picked up the manual for the car and now found that the ABS might have a vacum leak. I will check it out and let you know.
02/24/03 was definetly not the problem!
sheldonbailey is offline   Reply With Quote
Bookmarks
Google
Web AF
