Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier
Old 02-10-2005, 05:27 PM   #1
GotZ24
GotZ24 Normal reputation
sticky shifter
does anyone know how to get the gear indicator (PNRD21) out of the middle console in an 02? someone spilled something on it and now when i shift from park to reverse or drive i gotta pull pretty hard cuz the plastic is stickin together
GotZ24 is offline   Reply With Quote
Old 02-10-2005, 06:19 PM   #2
Knifeblade_03
Knifeblade_03's Avatar
Knifeblade_03 Normal reputation
Send a message via Yahoo to Knifeblade_03
Re: sticky shifter
possible~~~~~~~`There may be a U-shaped retainer ring that holds knob to shaft, mini-screwdriver will pry that out, don't lose the damn thing, lol. Remove the console trim plate, if no visible screw attachers, by EASY upward pull, one corner at a time, work the trim plate up very nicely, don't horse it. Do this carefully, a wire harness is most likely attached to the plate, so as it lifts, look!!!!!!. Once up, disconnect the harness/plug, slide up the trim plate over the shaft, and jope that puts ya where ya need to be. Reverse the above to-reinstall.
Knifeblade_03 is offline   Reply With Quote
Old 02-10-2005, 11:13 PM   #3
GotZ24
so that piece of trim should just pop right up, i tried that a little and it seemed attached somehow. but i didn't try to hard, didn't wanna break it
Old 02-11-2005, 06:53 AM   #4
Knifeblade_03
Re: sticky shifter
yeah, there are clips you can't see, sort of pressure-spring type that hold the trim plate to the console. They don't release easy. If ya hesitant about it, check with parts-store, they may have a diagram avail. you can look at to visualize how to release the plate. I've only done this once, so I no real expert at it, but it was a bear to release the clips.
Old 02-13-2005, 11:20 PM   #5
GotZ24
alright, thanks. i'll give it a try tomottow and let you know how it goes
Old 02-14-2005, 08:01 PM   #6
Knifeblade_03
Re: sticky shifter
one other thing, pull the inside tray of your armrest console. You may see a small screw or bolt that holds the plate in.
Bookmarks
Google
Web AF
