Tune up
98AUR0RA
02-10-2005, 02:30 PM
Hi i believe my car needs a tune up. I never did a tune up before. Is it hard. I would take it to the mechanic but im really straped for $. what do i need to do to tune my car up? what parts do i need?
treeboy38
02-10-2005, 04:44 PM
Spark plugs and wires
fuel filter
air filter
are the ones off the top of my head
OldsAuroraMan1
02-11-2005, 12:41 AM
fuel filter
air filter
Add the PCV Valve as well (right rear of engine on top of the valve cover) AND USE ONLY GENUINE GM PLUGS AND WIRES!!! Do not use other brands - they will haunt you on these two items. The Aurora engine is picky with plugs and wires. Not to bad a job to do, just take your time, esp with those back plugs.
You will need to remove the Coil Pack, two 10mm screws on front and two on back. Also, try to keep the new wires configured similarly with the old ones. GM makes special note of this in their shop manuals. Just did mine two weeks ago and all went AOK. Just do not rush it. You do not want one of those plugs snapping off on you and they will take a good bit of muscle to remove.
