2001 Bonneville PCV valve locationbartron 03-17-2002, 07:01 PM I know this may sound like a stupid question to some of you. But i need help in finding the pcv valve location. I cant find the thing. It might be in some odd location like the battery is under the rear seat. So if anyone can help me i would appreciate it. mitch9465 08-29-2002, 03:00 AM It should be located up front of your engin, on the valve cover, there is a small black hose running to it, pull stait up, pull out the PVC valve and replace. I think ;) FFrank 10-12-2003, 01:52 AM Check out this page. I think it has your answer. http://www.impalahq.com/HowTo/PCV.html phaley 11-10-2003, 10:13 AM Check out this page. I think it has your answer. http://www.impalahq.com/HowTo/PCV.html It is not obvious. On passenger side top of engine you will see some wires going into a sensor near the valve cover, pull up on this sensor and the pcv is underneath. markwb 11-11-2003, 10:36 PM FFrank, In reference to the Fuel Injector Sight Shield rubber piece that falls off easily, I bought a new piece and super glued the silly thing to the extension on the sight shield. It has stayed in place ever since. It's kind of a flimsy set-up there in the way it slips into the bracket. mr_meatplow 02-18-2005, 04:12 PM If you have a 2001 SSEI edition (supercharged) the PCV location is at the back of the motor right in the middle. Firewall side on the very top. It is hidden under a black diamond shaped plate that is held down by 2-10mm nuts. The plate is completely flat with NO WIRES OR HOSES going to it. Remove the plate and pull the spring out, and use a pair of pliers to lift out the PCV. Don't loose the rubber o - ring or the motor might run crappy after. I spent an hour trying to find the thing and everything on the web and in the manual is for a different style motor (96-2000 or non supercharged maybe) were the PCV is under the MAP sensor on the passenger side. After I wiped the dust off the black plate I noticed it said PCV on it - a head slap followed. Automotive Network, Inc., Copyright ©2012
