Installing Power Door Locks in 99 Dodge Ram
CrissCross
02-10-2005, 10:52 AM
Hello all,
I will be installing Power Door Locks in my 99' Dodge Ram.
this truck does not have existing power windows, door locks or a security system at all.
I have purchased a Micro DLR4 from http://www.bought4less.com
Comes with actuators and 3 built in relays.
I wanted to see if any one has installed power door locks on a 99 Dodge Ram before and has some advise to give. I am also looking to find a place to splice into the Ram's wiring harnes but not sure what wires are what so if any one has any wireing digrams for the 99 ram this would be great.
I need to hook up the following to the factory wireing harnes and Im trying to find a decent location so that I dont have to tear down the stering colum to do it. Lol :)
I) Pin#1: MAIN POWER-RED:
Connect the red fused wire to a constant 12v positive source. Micro
recommends direct connection to the battery. Be sure to fuse this wire,
An amp atc fuse and holder are provided for this. Be sure all
connections are fully insulated.
2) Pin#2: GROUND-BLACK:
Connect to the negative terminal of the battery or to a solid chassis
ground. Improper grounding will cause malfunctions. Be sure ground
is clean and well insulated.
3) Pin#3: +l2v SWITCHED IGNITION-YELLOW:
Find the wire that supplies switched positive l2v to the ignition. This
wire is usually located in the steering column li;irites ‘Ihis Wile will
have positive I 2v when key is in ignition position and when starter is
crankine.
4) Pin#4: +12v PARKING LIGHT OUTPUT-WHITE:
Find the wire that supplies positive l2v to the parking lights only. This
wire is located at the headlight/parking light switch or the light itself
DO NOT CONNECT THE HEADLIGHT WIRE OR THE UNIT WILL
BE DAMAGED! Vehicles with independent left and right signal.
I will probably do this this weekend. Thanks in advanced.
ponchonutty
02-10-2005, 08:24 PM
You'll have to run all the wires through the doors to the motors. You can't splice into and OEM wires to make them work. Also, pay attention how you mount the motors so they are not in the way of anything. I usually do not fully tighten everything until I know it all will work as is. Otherwise the set screws and such will loose their effectiveness.
As for the power and such, take the knee knocker off and you'll see all of your power wires going up into the column. Goto www.bulldogsecurity.com and look up the info on your truck for which wires to use.
CrissCross
02-15-2005, 08:53 AM
Ok got the new system in the mail looking to install it this weekend since it cam in a little late
ponchonutty
02-15-2005, 07:49 PM
Cool. Make sure to take your time and make sure the linkage doesn't bind.
CrissCross
02-20-2005, 04:14 PM
Well the install went fine. I will post a basic on the installtion if any one is intrested. It took just about 8 hrs. Very time consumming and well the result was great.
Converted manual locks to power locks.
Add remote keyless entry.
Parking light confirmation.
On start lock doors.
On Engine okk unlock doors.
