Blinker troublepipedope 02-10-2005, 10:43 AM I own a 1995 Dodge Intrepid, and i had a front pass-side blinker bulb go out...so I replaced it...then all my blinkers stopped working, so being the "know-it-all" I am, figured it was the fuse. Well, I guess I was wrong, the blinker fuse on the side-dash fuse box, seems to be in good shape ( 10a )...I even tested it on my interior, (also a 10a )...also, next to it is my radio fuse ( 10a ), and it hasn't worked in a while, but it seems good as well...but I need to figure out this blinker issue, any suggestions? AWP9521 02-10-2005, 01:02 PM I own a 1995 Dodge Intrepid, and i had a front pass-side blinker bulb go out...so I replaced it...then all my blinkers stopped working, so being the "know-it-all" I am, figured it was the fuse. Well, I guess I was wrong, the blinker fuse on the side-dash fuse box, seems to be in good shape ( 10a )...I even tested it on my interior, (also a 10a )...also, next to it is my radio fuse ( 10a ), and it hasn't worked in a while, but it seems good as well...but I need to figure out this blinker issue, any suggestions? Does the hazzard flashers work? Those run off the same flasher, it might be possible the flasher went bad. if the hazzards do work, since you said you also have a radio problem anf possibly other things not working I would try giggling the ignition switch and see if they start working again if so then the switch needs replaced. also cycling the hazzard switch a few times may also cure the problem. theFREAKnasty82 02-10-2005, 04:28 PM did you put the right bulb in place of the replacement? I believe it takes a 3157; anything else won't work. Automotive Network, Inc., Copyright ©2012
