95 Aurora Overheating Problem - HELP95AURORAMAN 02-09-2005, 05:16 PM 95 Aurora-Never have had overheating problem with car (103K miles) drove to local store (1 mile or less) temp gauge showed overheating-turn engine off message came on, shut it down & let it cool-no heat coming out of vents inside (turned climate control to 90) checked and there is antifreeze in the reservoir, no visible leaks. Cooling system was flushed & refilled by dealer at 85K. Does anyone know what the problem could be? Thanks Sweet William 02-10-2005, 09:19 AM Broken water pump belt? Angels_Aurora 02-16-2005, 10:37 AM burnt out fan relay? 95AURORAMAN 02-23-2005, 04:38 PM It was the water pump belt - replaced it running as great as always---Thanks for the help...........95AURORAMAN Sweet William 02-24-2005, 07:42 PM I love it when they are cheap and easy! lol amsur2003 02-25-2005, 01:41 PM I also had a overheating problem, It turned out to be the left oxygen sensor, it was bad. I hope this will lead you somerwhere. good luck! Automotive Network, Inc., Copyright ©2012
