96 Keyless entry programming.
96JimmySLE
02-09-2005, 03:29 PM
I was wondering if any one knows how to program the keyless entry fob for the '96. I know that the system is similar in the 95-96, but I havn't been able to find programming instructions for my '96. Please let me know.
96Jimmy
02-09-2005, 10:36 PM
1996 CHEVY / GMC KEYLESS ENTRY REMOTE PROGRAMING . INSTRUCTIONS PLEASE READ CARE FULLY BEFORE TRYING!IF AT ANY TIME YOU MAKE A MISTAKE PLEASE START AND STOP YOUR CAR, EXIT THE VEHICLE AND START OVER.95-99 VEHICLES REQUIRE A TEST LIGHT OR WIRE FOR PROGRAMMING.FOR BEST RESULTS BUY AN INEXPENSIVE TEST LIGHT.
1 .LOCATE THE DIAGNOSTIC PLUG LOCATED UNDER DRIVERS DASH, A USUALLY BLACK FEMALE END PLUG, APPROX. A 12 PIN CONNECTOR.2 FIND A GOOD GROUND AND TOUCH TEST LIGHT TO THE TOP PIN ON FAR RIGHT OF DIAGNOSTIC PLUG,POWER DOOR LOCKS SHOULD CYCLE.(JUMP UP AND DOWN)IF LOCKS FAIL TO CYCLE TOUCH BOTTOM RIGHT PIN. 2a - some older models ,early 96 on back you may have to touch top or bottom far left pin.( IF YOU HAVE A GOOD GROUND, YOUR TEST LIGHT WILL COME ON AND DOOR LOCKS WILL CYCLE FORM ONE OF THESE PINS! IF LIGHT DOESN'T COME ON YOU HAVE A BAD GROND!)3 AS SOON AS LOCKS CYCLE, KEEP THE GROUND AND PIN CONNECTED , HOLD DOWN BOTH THE UNLOCK BUTTON AND LOCK BUTTON ON THE NEW KEYLESS REMOTE AT THE SAME TIME UNTILL DOOR LOCKS CYCLE.(THIS MAY TAKE 5-20 SECONDS)4 MAINTAIN CONNECTION WITH TEST LIGHT , TAKE 2ND NEW OR OLD REMOTE AND PRESS AND HOLD DOWN LOCK AND UNLOCK BUTTONS ON REMOTE UNTILL LOCKS CYCLE.5- 20 SECONDS.6 TAKE 2ND NEW , OR OLD REMOTE AND HOLD BOTH UNLOCK AND LOCK BUTTONS DOWN UNTILL LOCKS CYCLE.(MAY TAKE 5- 20 SECONDS)7 TURN KEY ON, THEN OFF.YOU ARE DONE, EXIT VEHICLE AND TRY YOUR REMOTE.
96JimmySLE
02-16-2005, 07:23 PM
Worked like a champ! Thanks!
GeneP
02-19-2005, 01:49 AM
By chance would this same proceedure work on a 97 Jimmy?
Thanks,
Gene
