Any significant differences between 3.1L engine and 3100cc engine
wildman334
02-08-2005, 01:05 PM
My parents have a 94 Buick Regal. It presently has a 3100 engine in it, which is blown. They were considering putting a another engine in it. I have found several 3.1L engines. Since a 3100cc and 3.1L are the same size? Are there any significant differences in these engines that would make it difficult to place the 3.1L into a vehicle which had a 3100 engine in it?
Thanks for any information on this.
Ruley73
02-08-2005, 11:25 PM
The main difference between the 3.1L MPFI and 3100 SFI engine is the intake manifold. The heads are also slightly different. I would assume the computers are different because the 3100 has a Mass Air Flow Sensor and no Manifold Absolute Pressure (MAP) Sensor and vice versa applies to the 3.1L.
You could just do a computer/ECM swap to remedy this. This is easier said than done because your '94 Regal has an ECM controlled transmission (4T60E). I'm also pretty sure that you must use a Buick ECM because your 4T60E transmission is from a Buick - your Regal. So you'd have to get a computer/ECM from a '93 Regal 3.1L because that is the only instance in which Buick mated a 3.1L with the 4T60E (1993 Century and Skylark only came with a 3300 V6 engine). You'd probably still need to do some custom wiring to make that work after all that.
It will be harder to find a 3100 from a Regal because the 3800 was installed in the great majority (about 80%) of 1994-95 Regals. Luckily, other 3100-powered W-bodies (1993-95 Olds Cutlass Supreme, 1994-95 Grand Prix, 1995 Lumina & Monte Carlo) are much more common and should work with no necessary mods or ECM swaps.
I hope I didn't confuse you. Good Luck! :)
dwalmop
02-09-2005, 09:36 PM
when you see 3.1L engines for sale, just find out what year it is. A lot of people list 3.1L because it means the same as 3100, so if you get one, just make sure it's made after 94.
