Odometer and Speedometer died
ws1
02-07-2005, 12:02 PM
My odometer and speedometer died on my 84 vw rabbit, however my fuel guage and clock still work on my dash. Is there any way to fix this...maybe a switch or something needs to be replaced? Also my horn just started to honk by itself. Any suggestions?
Thanks,
Bill
boschmann
02-07-2005, 05:35 PM
Ive had the button fail, also could be a defective horn ring. The speedo/odo stops because a little plastic drive gear inside slips on it's metal shaft. Repair kits are available, but it's a tedious job.
Unbeliever
03-01-2005, 01:47 AM
Thanks,
Bill
The speedometer cable probably broke. It is fairly easy to replace.
boschmann
03-01-2005, 03:02 PM
The slipping gear is more common on the A2's. In addition to the cable there is a black box on the firewall that the cable runs through that sets the oxygen sensor light. The internal gears on the box can fail.
termitesgraffix
05-09-2005, 01:16 PM
that's what happened to my 84 cabby... any leads to the repair kit, boschmann???
boschmann
05-09-2005, 07:04 PM
I could only find info relating to a Beetle, but the problem is the same & reair is similar. I know there used to be kits available to replace the gear (this site shows glueing it). Perhaps some of the soeedo repair websites still have the kit available.
http://laudeman.com/bug_speedo.html
