spark plug wiring '95 blazer
commander100
02-07-2005, 02:03 AM
I have a '95 S10 Blazer 4x4 4.3L "W" engine. It has the distributor cap with the side mount terminals.
I had a misfire in cylinder #5. Changed plug and ran fine. Thought I would change all plugs this weekend and the spark plug wires. Now it runs terrible. Shakes and no accelaeration. Don't know if I mixed up wires on distributor? No check engine light, yet.
What is the sequence around the distributor?
1-3-5 on drivers side and 2-4-6 & coil on passenger side.
I thought it was (going clockwise) 2-4-6-coil-1-5-3
What is the correct spark plug gap?
I've seen .045 and .060 mentioned. I used .045
Replaced plugs with AC Delco CR43TSM, same as originals.
Spark plug wire set Federal brand (only one in stock at 4 local stores)
BlazerLT
02-07-2005, 03:09 AM
http://www.tweaknews.net/img/firing.jpg
commander100
02-07-2005, 03:18 AM
[QUOTE=BlazerLT]http://www.tweaknews.net/img/firing.jpg
Are 1 & 3 reversed on the engine picture?
Thanks for the help.
Any idea what spark plug gap is?
rlith
02-07-2005, 07:28 AM
spark plug gap should be on your fan shroud, if not it should be .045
Engine cylinders as follows.
6 5
4 3
2 1
The cap will be marked with the proper numbers.
BlazerLT
02-07-2005, 11:22 PM
6 5
4 3
2 1
That is the wiring from the Chilton's repair manual.
TonyMazz
02-09-2005, 03:54 PM
Chilton manuals aren't worth the paper their printed on...
BlazerLT
02-09-2005, 04:01 PM
whoa whoa whoa....back the truck up there.
You are saying that you know more than what the manual says?
TonyMazz
02-10-2005, 10:32 AM
No of course not....just see pictures/pages that are different than the actual service manual for my year. i.e. spark plug gap .60 in the service manual .45 in chilton.
I think sometimes the cross multiple year things screws up these DIYmanuals as they try to be all things to all people over 5 years.
I have chilton 94-99 s-10 and see that #1 is on drivers side front, you show your's at the middle. where the infamous #3 plug is. The one that's a bitch to get out because of the steering....
My 99 #1 is up front and #3 is in your #1...if that makes any sense.
My sources for information besides the quick reference of chilton / haynes is online AllDataDIY (on line version of the service manuals / bulletins) and I bought the service manuals from Helmic....
So don't get yourself in a bundle, I get frustrated with in consistent information when it comes to these kinds of things...nothing to do with be smarter than anything or anyone.....
Capiche?
BlazerLT
02-10-2005, 12:47 PM
true, but with the small mistakes, it is still a great source of information for the back yard mechanic.
I don't know what I would do without mine.
blazee
02-10-2005, 01:16 PM
A guy in the s10 forum just swore the temperature sending units on the 96 and up were oil pressure switches because his Chilton Book told him so.
TonyMazz
02-10-2005, 01:37 PM
Yep doesn't surprise me at all...but we must take a look at various sources, and NOT totally trust the chiltons, haynes...or any manual.
They try to cover too much in a single volume and make too many generalizations...
So BlazerLT...you don't have the same problem as everyone else with the number #3 plug right in the way of the steering column on your 95 blazer ? There are sure alot of folks that have commented on that plug removal (#3) as being a real pain in the ass.
blazee
02-10-2005, 01:46 PM
I have found several mistakes in my Haynes manual as well.
A chevy service manual costs me two hundred dollars for repairs because it contained the wrong torque specs for the lower balljoints on my Impala.
TonyMazz
02-10-2005, 02:07 PM
Sorry to hear that....guess we are stuck using our heads and multiple sources....that's why I rely on this forum too....
I have found a few mistakes in positional things in my helmic manuals but have been 100 times better than haynes/ chilton...anyway...
all good discussion.....
BlazerLT
02-10-2005, 02:27 PM
I never stated anything about the #3 plug?
Where is that coming from all of a sudden?
TonyMazz
02-10-2005, 02:42 PM
...never mind...never said you did...just that a whole lot of 4.3L out there before and after it seems 95 have the #3 plug in the position that you quoted from chiltons diagram is your #1.
I will drop the whole thing....never mind
BlazerLT
02-10-2005, 03:11 PM
My image is indeed correct for 1995 Vin W and 1996+ 4.3L engines.
1 and 3 are swapped for the 1994 and 1995 Vin Z engines.
blazee
02-10-2005, 03:15 PM
I believe the issue wasn't the firing order, but that the picture shows #1 cylinder to be in the center of engine rather then the front where it should be.
TonyMazz
02-10-2005, 03:17 PM
:grinno:
I can not comment on 95 but my 99 has #1 and #3 reversed on your diagram. ...and I too have a "W" engine. Don't take my word for call a service tech.....
...and then I will accept your appology...
BlazerLT
02-10-2005, 03:19 PM
:grinno:
I just checked the Haynes manual, it is saying what you are saying.
This is friggin confusing.
TonyMazz
02-10-2005, 03:26 PM
That's a 10-4 good buddy..AllDataDIY shows the correct way too...
I'd show you but don't know how to show a diagram like you did....
...anyway...this is all I am saying...we get ourselves into trouble withouteven knowing it unless we check and recheck.... :iceslolan
blazee
02-10-2005, 03:39 PM
You can copy and paste it in. just highlight it, right click "copy", go to the post your reply part and then, right click "paste"
