heater control
ath1
02-06-2005, 01:41 PM
2000 jimmy, A/C system seems to work well, but there is no hot air. Coolant is circulating fine, and heater core is not plugged. I think the problem is electrical. The speed control, for the blower, fails to change the speed.
blazee
02-06-2005, 01:52 PM
How do you know the heater core is fine?
Where does your temperature go when the engine is completely warmed up?
ath1
02-06-2005, 03:05 PM
well both the inlet and outlet hoses are warm at normal eng. temp. Engine also comes up to temp, and is maintained. there are no leaks on the cooling system.
smonaldo
02-07-2005, 02:54 PM
Ok, I had the opposite problem. First, no heat because core needed purging. Then, no way to stop the heat, as there was no control of the temperature. That turned out to be the contol panel, $400 later! Mine is the ECC version, way more things to go wrong than the standard edition.
BlazerLT
02-08-2005, 03:51 AM
Stop being so general.
WHERE does the needle go up on the temp gauge when the engine has been run for awhile?
