amp for 2 re10
roach666
02-05-2005, 12:29 AM
After finally choosin these two re10, I'd like to have advice for a amplifer, they are both 175w rms so total 350w rms. They are dvc 4 ohm so I need a 2-channel or 1 channel amp powering about 350w rms at 4 ohm. Right? (I figure the wattage is split in 2) I've found the kicker350.2 but it's like 300$ ! Any ideas of a less expensive amp that could do the job?
thanks
threedd97
02-05-2005, 02:48 AM
Wouldn't a 9.2 handle those nicely? $215 for it. www.edesignaudio.com/
Edit: Fixed the link.
AndonD454
02-05-2005, 12:19 PM
nine.2s can be found at www.edesignaudio.com .. not adire. and yeah that would prolly work well but its underrated so far as i know.. so even though it says 400wrms @ 4 ohm its prolly more like 450 or maybe even 500. this is a very nice amp (my friend has one) but its still a nice chunk of change.
a profile AP600 would give you about 300 watts and its abotu $100.. but if you really need to max the power to em then they make an AP 1000 that gives 480 rms for like $125-140 but then you would have to be careful with how much power you let your subs have(as you would with the nine.2)
threedd97
02-06-2005, 03:50 AM
Er... lol. I don't know why I linked adire's site. I was insanely tired at the time.
bumpinstang77
02-07-2005, 12:52 PM
LOL. yea the profiles would be fine just make sure your CAREFUL with the gains..... the RE series doesn't take much power at all to get full ouput.
CBFryman
02-07-2005, 04:53 PM
while on the subject of ED amps. bumpin, do you have any experence with the NINe.1@4ohm? its rated to 450@13.5v. my voltage sits right around 14.2v except when cranking the truck up. where abouts do you think it will be at wattage wise?
Edit:
How will it handle 15v? im thinking of slapping a 16v altinator in there and putting a manual voltage regulator on it. this way i can charge my battery at 14.4 and run my assesories at 15v. but 15 is getting kinda high for a constant with assesories designed to operate from 12-14.4v.
