02-04-2005, 03:09 PM
location of 92 rodeo EGR valve
hey i was wondering where the egr valve was located on my 92 rodeo 3.1l, and also how to remove it, i want to clean it out, any help you be appreciated, picture would be even more help, thanks guys
1995 Nissan Maxima se FULLY loaded, now 136k, BOSE, climate control, sunroof, heated seats, green w/tan leather...repairs ive done to it: new rear calipers, pads, rotors, new exhuast from cat back, new spark plugs, fuel filter, 4 new tires, new starter
1998 Ford Taurus (3.0L) 80,000 miles and many headaches, wont buy a ford again
SOLD..... Isuzu Rodeo 5 spd...4x4... manual hubs....160,000 miles...
02-04-2005, 03:12 PM
Re: location of 92 rodeo EGR valve
i have read stuff on here about i think 98 rodeos egr locationa nd cleaning procedure, but i have no idea where my 92 is located, just to clear that up, i have already read how to do it, but i just need to know where it is
02-05-2005, 03:11 AM
not sure on the 3.1 models dont work on many of them you may want to ask sthe guys in one of the GM forums as the 3.1L engine is a GM engine
02-05-2005, 10:41 AM
thanks for the tip, wheres the gm forum?? i looked at all the forums and didnt see it
02-18-2005, 02:24 AM
the EGR valve is located behind the TBI unit on the intake manifold. It is shaped kind of like a mushroom and is held in place by 2 10mm bolts. you will also need a replacement mounting gasket available at your local auto parts store
1991 rodeo LS 4x4 v6 5-spd
1988 cavalier Z-24 3.1HO 5-spd
1993 lumina euro 3.1
1978 camaro z-28 377stroker 5-spd
1989 5.0L mustang conv.
we the unwilling, led by the unknowing, are doing the impossible, for the ungrateful. we have done so much, for so long, with so little, we are now qualified to do anything with nothing.
02-18-2005, 10:22 AM
Although it's a crummy picture, the egr is the spaceship looking thing underneath the breather and where the cables meet.
I was leaning into the engine compartment over the driver's side fender to take the pic. There are 2 bolts holding it to the engine. The bolt heads face the right side of the picture (firewall). There is a single hose connected to the egr that has to come off. Some carb cleaner or brake cleaner and a small wire brush is handy to clean it. You should be able to push the vacuum inside the egr easily with your fingers:
HTH,
Steve
ps. Props to imageshack.
