2 or 3 inch lift?
thinmints
02-04-2005, 11:35 AM
i have a 96 XJ was wanting to put either a 2 or 3 inch lift on it, im just wondering if i will have more suspension problems with the 3 inch lift and should i just put the 2 inch one on and avoid any possible problems ( Death Wobble) :banghead:
paulsenior
02-04-2005, 12:28 PM
I just got done adding a 3 in lift to my 91 XJ. I dont know what the difference is between the years. But I did the install without any major mishaps. I get a little vibration at about 50 and then its subsides at 55, nothing to bad, An alighnment should fix that :p
MagicRat
02-05-2005, 02:44 PM
I would suggest the less lift the better for all around use.
What size tire do you want to use? Select a reasonable tire and only lift enough to clear them.
thinmints
04-05-2005, 12:16 AM
i just put a 2 inch lift on my 96 and wanted to get new tires i currently have 235 75 16 on them i would like to get a tire that will fill up the wheel well without rubbing any suggestions on what tire size i should get??
paulsenior
04-05-2005, 12:32 PM
31's are the biggest size you could fit without rubbing, I have a three inch lift running 32's the only time they rub is when I turn completly in one direction
