Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Mercedes-Benz > SL
Old 02-04-2005, 08:36 AM   #1
timzbenz
timzbenz Normal reputation
Can't select park so won't start..
Hi folks,
On my second trip in an 1983 500SL Auto, I turned off the engine with the auto transmission still in drive. After shopping for 20 mins, I can't start the engine - battery looks ok (no dimming off the heaadlights when trying to start). I think it's because I can't select neutral or park. Indeed, with the ignition on, gearshift in Park, I can roll the car back and forth any distance without any locking, indicating it's still in gear.
The gearshift is very free (electronic, not mechanical?), and no gearbox noises as I shift between gears.
Am I missing something here - doing something wrong, or a blown fuse? I've spent hours on the web looking, nothing. Any help much appreciated.
Thanks in advance...
timzbenz is offline   Reply With Quote
Old 02-04-2005, 06:38 PM   #2
talonlover
talonlover's Avatar
talonlover Normal reputation
Re: Can't select park so won't start..
Have you tried starting with the selector in neutral? This is just a shot in the dark but maybe the neutral saftey switch? Then again that wouldn't explain why it's still in gear. The only other thing that comes to mind is that maybe the shift linkage has come loose.
1992 Eagle Talon Front wheel drive 13.3@108mph...SOLD
1991 300ZX..MINT!, BMW Z-3, 2003 Honda VFR800 Interceptor
1981 DeLorean DMC-12 restored by DMC in 2007
talonlover is offline   Reply With Quote
Old 02-04-2005, 06:40 PM   #3
talonlover
talonlover's Avatar
After reading your post a bit more carefully it sounds just like the linkage has come loose. Probably just worn out shifter bushings...you might get the linkage back in to get it on a lift but your still in for a fun time getting those little $%^%$'s in place
Bookmarks
Google
Web AF
