Rear Wiper Bezel removalthinmints 02-04-2005, 03:01 AM I have a 96 xj i need to replace the rear wiper bezel, does anybody know how to remove the wiper arm? i tried pulling it but that didn't work, i looked for some sort of clip to push but didn't see one thanks... runuover 02-04-2005, 06:18 AM [QUOTE=runuover]pull the clip out and the wiper back and wiggel it and it should come out. its a little slide clip. stevelock 02-04-2005, 08:23 PM lift the blade off the window look on the arm right were it goes to the motor. you will see a small clip that you can slide out about 1/4" than let go of the blade and grab the arm move shake alittle it will than pull off. hope this helps Jay83LeSabre 02-04-2005, 08:27 PM If it is like most other Chrysler products you may have to fight it off. Typicly when we replace caravan and voyager back windows and windshields the wipers are a bear to get off. You can try to heat it with a propane torch, you don't have to get crazy, just a little bit of heat and some muscle will get it off. Usually they are rusted or corroded on there. If and when you get it off, clean up the splines and put a dab of grease on it to reduce future corrosion. stevelock 02-05-2005, 07:21 PM If you didn't get it off yet let me know. I have a 96 I can go look :banghead: thinmints 02-06-2005, 12:55 AM If you didn't get it off yet let me know. I have a 96 I can go look :banghead: No the Damn thing will not budge i ripped out what i think was the clip so ........................ :1zhelp: stevelock 02-06-2005, 05:07 PM just got home I'll go out right now and look brb stevelock 02-06-2005, 05:18 PM lift the blade off the window look on the arm right were it goes to the motor. you will see a small clip that you can slide out about 1/4" than let go of the blade and grab the arm move shake alittle it will than pull off. hope this helps OK THIS WAS WRONG JUST WENT OUTSIDE AND LOOKED.:banghead: Lift the arm,you will see a little hole were it pivots You have to put something in the hole .like a 6 pen Nail To hold it off the glass. Than let go of the arm (It should be about 1“off the glass not holding it ) now Look you will see under it a little clip push the clip in and Pull on the wiper arm at same time . That should do it. thinmints 02-06-2005, 09:47 PM OK THIS WAS WRONG JUST WENT OUTSIDE AND LOOKED.:banghead: Lift the arm,you will see a little hole were it pivots You have to put something in the hole .like a 6 pen Nail To hold it off the glass. Than let go of the arm (It should be about 1“off the glass not holding it ) now Look you will see under it a little clip push the clip in and Pull on the wiper arm at same time . That should do it. Yeah that's the clip i ripped out.. ill try something else i hope will work stevelock 02-06-2005, 09:54 PM I think you need to push in on that clip :) pamandjack 02-07-2005, 04:29 PM I think you need to push in on that clip :) i am having the same problem i need to treplace the whole wiper did you figured out how to remove it??? please help thanks stevelock 02-07-2005, 05:46 PM [/I] if you look 2 posts up thats how i got mine off thinmints 05-21-2005, 08:40 AM Yeah that's the clip i ripped out.. ill try something else i hope will work Ok I NOW have the wiper off but i cant sem to get the bezel off i am unable to get the nut to unscrew. i can get it to turn but it will not move up or down it seems like it is stuck HELP :banghead: vamc 05-23-2005, 11:05 PM Bend the wiper arm back and that will release it. Try that.thats what i did to replace it. thinmints 05-24-2005, 01:42 AM Bend the wiper arm back and that will release it. Try that.thats what i did to replace it. I have the wiper asrm off, its the screw thats on there that wont come off ive tried to unscrew it both ways, it will move but it seems stuck where its at......... it just turns :confused: vamc 05-24-2005, 04:49 PM Put some wd-40 on that. turn to the left. thinmints 05-26-2005, 02:39 AM Put some wd-40 on that. turn to the left. Getting it to turn is the easy part its getting it to come off the screw is where i am having the problem it will spin in either direction but wont move up or down :banghead: Automotive Network, Inc., Copyright ©2012
