50k maintanance
TheFugitiveMind
02-04-2005, 02:42 AM
im approaching the 50k mark on my 01 passport and i was wondering what i should be doing. i have already adjusted my rear drum brakes, changed with fully synthetic oil as always. i am planning to change the spark plugs. what do you guys recommend? also what else should i be checking out?
Thanks!!!!
SOLSTER
02-04-2005, 04:42 AM
Here's a thread I did on 60K service. Start there?
http://www.automotiveforums.com/vbulletin/showthread.php?t=317539&highlight=solster+maintenance
Look at amigo-2k's faq page:
http://geocities.com/endre_rl/isuzufaq.htm
Then search "maintenance".
Then wait for some good general advice from our friends here on the rodeo forum!
SOLSTER
amigo-2k
02-04-2005, 09:45 AM
1. change all of the fluids (front and rear diffy, tranny, power steering, brake, h20, transfer case ...)
2. Plugs (make sure you buy the right ones and stay far away from Bosch double plats.
3. Fuel filter
4. Clean the EGR
5. replace the PCV
6. clean up the battery and the points where it grounds to (sp. the ground on the alt braket).
7. check the muffler out
8. check around for cv leaks and the likes.
and then ENJOY! for another 50k
Tonupboy
02-04-2005, 09:52 AM
3. Fuel filter
4. Clean the EGR
5. replace the PCV
Just to be safe: Would this apply to the 93-97 Rodeos too?
Dont forget to flush and replace your Antifreeze too!
