How to replace headlight assembly in 2000 Windstar
ddrye1
02-03-2005, 12:52 PM
Can anyone help with how to replace a 2000 Windstar headlight assembly?
rodeo02
02-03-2005, 06:52 PM
Pop the hood. You should see two black metal 'tabs' towards the back of the headlamp assemblies. Pull those tabs up, they will slide up & out and the headlight assy. will basically fall right out! REAL easy!
G/luck
Joel
ddrye1
02-03-2005, 08:32 PM
Thanks, I will give it a try.
fivedraw
02-05-2005, 10:51 PM
Are there any aftermarket HID headlamps for the Windstar?
born2run
02-19-2006, 04:50 PM
I am trying to replace burned out headlight on the driver side of 1 2001 Wstar. The inner clip slides out eay. But the outter clip, nearest the fender, will not come out. It looks like it has some teeth in it that prevent it from sliding? Is there a trick to geting this out. Same deal on the passenger side.
Spent 2 hours looking at this and the owner manual is useless. Thanks.
