you might need the 99-00si rear mount. not the chassis mount but the t mount or whatever they call it that bolts into the rear of hte tranny. again not sure because i havent done a swap like this before.
did the conversion harnesss come with instructions on how to rewire it ?
The easiest thing to do is to use your stock OBD2 injectors, swap voltage regulators in the alternators, and change the 1 plug from the OBD2 dist to the 2 plug of the OBD1. Here is a thread from H-T, but you'll want to do the opposite of what it says for the alternator and distributor because it's for OBD2 motor in an OBD1 car: http://www.honda-tech.com/zerothread?id=550976 (6th post down).
hey, I need some help too with the same engine, is a LS 95 going into my 94 civic hatch.. I have the axles, linkage and shifter,tranny and the engine of curse.... the only thing missing are the motor mounts. which ones I have to use? all the integra's or a cuple of them?
