Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Kia > Sportage
Old 02-03-2005, 07:10 AM   #1
bbrigham
bbrigham Normal reputation
Send a message via MSN to bbrigham
Unhappy 1998 Sportage over heating
My sportage had a small antizreze leak from a metal tube behind and under the alternator.
So like an idiot in a hury I put some stopleak in and now it stoped leaking and is overheating like crazzy.
Thermostat ? if so where is the bugger and how had is ti to change.
bbrigham is offline   Reply With Quote
Old 02-03-2005, 07:24 AM   #2
LMP
LMP's Avatar
LMP Normal reputation
Thermostat is right in front of the engine, near the timing belt cover...picture 6 on the pdf document you already have...
....ahh.....I have always been puzzled trying to understand how stopleak can know what it is supposed to block, and what not..??..so it is on my blacklist.
I don't believe in miracles.
LMP is offline   Reply With Quote
Old 02-03-2005, 09:16 PM   #3
bbrigham
Re: 1998 Sportage over heating
Guess what!
Thermostat was fine.
Problem was when I was messing around I bumped temp sensor wire and seeing that it was rusted some of the wires broke adding resistance and making the gauge reed higher than temp really was.
Old 02-04-2005, 03:36 PM   #4
LMP
LMP's Avatar
Re: Re: 1998 Sportage over heating
Having no problem is better than having a solution...
Old 02-04-2005, 04:27 PM   #5
bbrigham
Guess what!
Wrong again dam thing is really overheating. Thermostat is out now.
What do you think the next step should be?
How do you test water pump or radiator?
I checked oil and no water in it.
Water just keeps spouting out radiator neck when heated up.
Help!!
Old 02-04-2005, 09:45 PM   #6
LMP
LMP's Avatar
EH wait: before you used the stopleak, wasn't it doing fine? If you did not have any overheating symptoms before the stopleak, then keep it simple. I think the sudden change in behaviour is related to the actions that have been taken...I fear stopleak can block radiator cells as well as unwanted leaks. I do not like additives of any kind, but here and now I'd try a radiator cleaner hoping to remove stopleak from where it should not be...and reverse the situation.
Do you get normal heat from the heater?
If you or anyone else ever goes to change the water pump make sure you get an original from KIA..there have been SEVERAL cases of aftermaket pumps that LOOK like the right one but that are for the SOHC engine..and they do not have exactly the same belt teeth spacing and installing that pump destroys the timing belt in a few days or a week.
Old 02-05-2005, 07:48 PM   #7
bbrigham
I installed a flushing TEE and flushed radiator three times then added supper clean. will run tomorrow flush and fill with antifreeze.
BBrigham
Old 02-12-2005, 03:57 PM   #8
bbrigham
Everthing Works Fine
It took alot to get stop leak out but all is fine now.
Thank You
BBrigham
Bookmarks
Google
Web AF
