Radio and Door Window Problems - Help Appreciatedjacclark 02-02-2005, 04:23 PM Did something very silly the other day which resulted in a long day replacing fuses. Everything seems to work except for the radio - I get power to the Inifinity Gold Radio as the antenna goes up and the little lights on the equalizer go on but no sound. Is the radio dead and do I need to replace it? If I do, any suggestions? Also, I've had this problem for a while but the passenger window switch UP works intermittently. When it doesn't work, if the driver window switch is help up while the passenger holds up, it works for a while. Any ideas? Thank you. Jay lcarder 02-03-2005, 02:48 PM Is your amp fuse ok? Not sure if it has a separate one, but it could be the problem since your radio comes on and you don't have sound. jacclark 02-04-2005, 09:26 PM I don't have any knowledge in this area. Where would the amp fuse be? I'll take a closer look at the amp in the morning. You're right in that the radio seems to work - i had the panel display problem - but even now the eject button ejects the cd and the lights to the equalizer all come on. Thanks! Automotive Network, Inc., Copyright ©2012
