RIMS - will these work?vixes 02-02-2005, 09:13 AM I drive a 2003 celica GT. Tires read 195/60R15 Rims I am looking at are: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=7951134372&rd=1&sspagename=STRK%3AMEWA%3AIT They are 15 inches but it gets into detail about bolt placement and stuff, which i know nothing about. If anyone could give me the thumbs up or down for if these would work, that would be awesome! Thanks nialusa 02-02-2005, 09:23 AM Dosnt the 2003 Celica come with 16" alloys on as standard? why would you want to put smaller wheels on your car? Celica has a 5 x 100mm bolt pattern and the standard wheel has a 39mm offset so no, they wouldnt fit. 91 Celica St 02-02-2005, 12:00 PM th smaller the wheel diameter the less power you loose to the wheels.... try n keep the overall size the same cuz your spedo wont ever be correct if not.. theres a gear in the spedo that goes off how many revolutions your tires go...bigger the tire the longer the revolution, im going like 27 when t says 25...not a big change but just a thought nialusa 02-02-2005, 12:21 PM If you want bigger wheels, just have lower profile tyre`s. the rolling distance will be the same. Even though I have 18`s on, with the tyres I have, the rolling distance of the wheel is slightly less than the standard 16`s. there is a site where you can work out which size tyres you can run to maintain the same rolling distance as the standard set up on your car. celica`s can take up to 19 inch alloys without changing the rolling distance of the wheel, with the correct tyres fitted of course. 235/30/19`s I think. 91 Celica St 02-02-2005, 12:24 PM fo sho i went from 13's w 185-75 to 16's w 205-50 nialusa 02-02-2005, 12:55 PM fo sho i went from 13's w 185-75 to 16's w 205-50 Found the site- with those tyre sizes the rotational offset is only 0.6% which means that every mile that you travel, your wheels will turn 2.9 less times than the standard. Which i doubt very much will change your speedo reading. http://www.miata.net/garage/tirecalc.html vixes 02-02-2005, 05:58 PM Thanks for the info. Automotive Network, Inc., Copyright ©2012
