Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 02-01-2005, 10:15 PM   #1
unknown_sender12
unknown_sender12 Normal reputation
Unhappy 94 s-10 trouble starting lopes while idling
i have a 4.3L in my 94 s-10.. for a few months ive been having to hold the key for a long time to get it to start and give it some gas.. i usually let the fuel pump run until it stops before starting it but it only seems to help very little.. if i turn the key to acc then back to run the pump will usually run a second time and then usually it starts easier.. why would this be and how can i make it so that i dont have to do this all the time.. also when it idles it speeds up and then almost stalls then speeds up again it does this until u run it above 1000rpm(just a guess i dont have a tach) also i seem to be running ritch.. i havent tried much just mostly injector cleaner and changing plugs..
Thanks matt
unknown_sender12 is offline   Reply With Quote
Old 02-01-2005, 10:27 PM   #2
BlazerLT
AF -Advisor
BlazerLT's Avatar
BlazerLT Normal reputation
Re: 94 s-10 trouble starting lopes while idling
Check your CPI injector for leaking through the IMTV valve hole under the vortec name plate.
Remove and clean and scrub your IAC valve and the hole it inserts into and make sure they are both clean and then reinstall.
Then remove and check your EGR valve. Clean, and then reinstall.
Then reset the computer by pulling the negative cable off of the battery for 10 minutes, then reattach it, start your engine and allow it to relearn the idle.
1995 Factory Blazer Service Manual for sale, PM if interested.
BlazerLT is offline   Reply With Quote
Old 02-01-2005, 11:12 PM   #3
unknown_sender12
so where bouts is the EGR.. i have Haynes repair manuals but the egr valve they show in here i cant seem to find
Old 02-01-2005, 11:32 PM   #4
BlazerLT
AF -Advisor
BlazerLT's Avatar
just to the left of the intake.
Old 02-05-2005, 09:23 PM   #5
caryga
caryga Normal reputation
Just today I got the same issue and my check enine soon light came on. Very rough idle and stink, stink, stink. Once the RPM's go up the issue appears to go away. I went to my local parts house and the code said ERG failure. Pending what code the ERG is it will cost 59-79 bucks. There is one code out there that will set you back $230. I have not found what I have yet, hopefully a good cleaning will fix the issue.
BlazerLT
What is an IAC you recommend cleaning? I am not familiar with either of these parts. Are they easy to install yourself? Any on-line reference guides? Would a bad ERG also take a few gallons/mile off of the fuel ecomony?
THanks!!!
caryga is offline   Reply With Quote
Old 02-05-2005, 09:28 PM   #6
BlazerLT
AF -Advisor
BlazerLT's Avatar
Remove the EGR valve and clean out the carbon kepping it plugged open. Do NOT replace the valve, just clean and reinstall with a new EGR gasket.
The IAC is the idle air control valve and should be cleaned every once in a while to clean out it and the hole it inserts into.
I would recommend buying a repair manual and do some searching around the forum to find out more information.
Bookmarks
Google
Web AF
