Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Tacoma
Old 02-01-2005, 12:33 PM   #1
timmstng67
timmstng67 Normal reputation
1999 toyota hesitation at low rpm
My 1999 toyota tacoma hesitates just of idel if i lift of gas pedal and press on it again it will seem to fix problem it only dose it under a slight load 1st or 2nd gear sometimes 3rd but just at low rpm it runs great at high rpms and idels great can some one help ???????
timmstng67 is offline   Reply With Quote
Old 02-24-2005, 12:16 PM   #2
timmstng67
Re: 1999 toyota hesitation at low rpm
[quote=timmstng67]My 1999 toyota tacoma hesitates just of idel if i lift of gas pedal and press on it again it will seem to fix problem it only dose it under a slight load 1st or 2nd gear sometimes 3rd but just at low rpm it runs great at high rpms and idels great can some one help ???????[/QUOTE= Would not think Plugs would do it !!! I had a set of Autolight platiums installed they had less than 1000 miles on them put a set of NGK platiums in and problem was fixed !!!!!
Old 02-24-2005, 01:43 PM   #3
Flash75
AF - Advisor
Flash75 Normal reputation
Thanks for letting us know what fixed the problem. Too bad none of us had a suggestion for you when the problem was first posted. Autolite light plugs are made by the same people that make Fram filters. I don't trust their filters and usually stay away from their plugs.
Clifton
Flash75 is offline   Reply With Quote
Bookmarks
Google
Web AF
