replace fog light bulbmy00montana 02-01-2005, 09:29 AM does anyone know the easiest way to change a fog light bulb on 2002 alero. ttwotees 02-26-2005, 08:52 PM This is easier if you put your Alero on ramps or a hoise or on jack stands (of course I'm old and have a hard time crawling under the car). Below the bumper there are several plastic protection panels. The one you want is the one held in place by a bolt (10mm) that you can see through the bumper cover below the fog lamp. Remove this bolt and the plastic panel should drop down so you can access the fog light bulb. Grasp the bottom of the bulb with the wire connected and twist counter-clockwise (from the bottom) and remove from fog light. Disconnect the wiring plug from the bulb. It's held in place with two snap locks. Simply pry each snap lock on each side of the socket at the same time and pull the bulb from the plug. Since you are accessing the fog light bulb, it must be burned out so you should have your replacement #894 bulb handy. When installing the new bulb, DO NOT TOUCH the glass part of the bulb. The oil in your skin will fry the bulb. Grasp the bulb by the bottom and observe the location and size of the locking projections just below the glass bulb on the plastic base and how it fits in the fog light socket. Put the bulb in the bottom of the fog light without the wiring attached and twist clockwise until locked (1/4 turn) Then insert the wiring plug into the bulb base socket (it can only go one way due to a nib in the socket for that purpose (Best to look at the bulb and plug prior to inserting it so you can tell which wat to insert the plug when ready. Re-attachthe protective cover with the bolt and Voila, you're done! :p ttwotees 03-06-2005, 01:17 PM does anyone know the easiest way to change a fog light bulb on 2002 alero. Second post on thread; Found out that you replace the fog light bulb by removing the headlight (very easy). Simply pull up each of the two guillotine blade locks located on the top rear of each side of each headlight. Pull up, which releases the healight on each side (you may have to slightly wiggle or push the blade lock slightly down to align the holes in the lock with the protrusions on the back of the headlight) Then pull the headlight out toward you and disconnect all of the wire leads (two twist-lock bulb wires and one snap type plug connector). Once the headlight is out, you can see the fog lamp below and the bulb can be replaced by removing the twist lock connector and replacing the bulb. Reinstall in same reverse order. ttwotees :loser: Automotive Network, Inc., Copyright ©2012
