CPS questionsrustedwon 02-01-2005, 01:57 AM If the CPS starts going bad I realize that starting the engine becomes more difficult.Does this also figure in with the overall running of the engine,such as timing?Ive checked my CPS on my 89 4.0 and it reads 380 ohms resistance.I beleive this is means its starting to go bad,would this also make it idle rough? gtmud 02-01-2005, 09:11 AM CPS? What part are you talking about? TPS? rustedwon 02-01-2005, 02:43 PM OOPS!!!Crank position sensor! gtmud 02-01-2005, 02:50 PM I feel stupid, Yes it could make it run rough, if you checked it and its out of the tolerance, than I would replace it. Not sure how involved it is, let me know how it goes. Dale Aeppli 02-01-2005, 06:42 PM OOPS!!!Crank position sensor! give year make and engine Dale jeepman600@sbcglobal.net rustedwon 02-02-2005, 02:11 AM give year make and engine Dale jeepman600@sbcglobal.net 1989 jeep cherokee 4.0L Dale Aeppli 02-02-2005, 05:49 PM If the CPS starts going bad I realize that starting the engine becomes more difficult.Does this also figure in with the overall running of the engine,such as timing?Ive checked my CPS on my 89 4.0 and it reads 380 ohms resistance.I beleive this is means its starting to go bad,would this also make it idle rough? Ohms early 4.0's 125- 275ohms at terminals A & B on ignition control module mounted on shock tower. Dale jeepman600@sbcglobal :2cents: muskypro 02-04-2005, 11:01 PM my 90' 4.0l L6 takes a while to crank over. could it be that too?? i just have delt with it. not know what it was! Thanks Justin Dale Aeppli 02-05-2005, 04:29 PM my 90' 4.0l L6 takes a while to crank over. could it be that too?? i just have delt with it. not know what it was! Thanks Justin Hi, possibbly , how long has it been since a full tuneup,--plugs, plug wires cap and rotor. Air filter change. Plus throttlebody cleaning. Dale jeepman600@sbcglobal.net Automotive Network, Inc., Copyright ©2012
