Modifications List Thread ...
Philosopher
06-26-2001, 05:13 PM
Aquamander made me think of this when he was talking about his brother's X and how he is jealous of Aqua's ...
How about a "Modifications List" thread? Not a "Wish List" thread, but what you have on your truck right now. That way, some of us will know who to ask for certain things, who has what on their truck, etc. If this isn't a good idea, then nevermind. :)
Here's mine:
2000 NISSAN XTERRA XE V6 4X4 M/T Sport/Utility/Power Packages
Nissan Cargo Area Protector
Nissan Rubber Floor Mats
SUSPENSION
2” Torsion Bar Lift
PowerBarz by Sway-A-Way Heavy Duty 27.48mm Torsion Bars
Gothamist’s MAXC Front Anti-Sway Bar Quick Disconnects
32 X 11.5 R 15 BFGoodrich Mud Terrains
6 Spoke 98 Pathfinder Aluminum Wheels
Rancho RS9116 Shocks in Rear
Warn Premium Manual Hubs #29091
Replaced Rear Leaf Springs Under Warranty
Spencer Low Racing 2” Rear Shackles - http://www.spencerlowracing.com
Rancho Add-A-Leaf Part # RS510 / P57022
Rear Anti-Sway Bar (Removed)
Energy Suspension Low-Profile Bump Stops #9.9102R (Removed in favor of stock bumps)
BUMPERS & RECOVERY GEAR
ARB Xterra Bull Bar w/ Gothamist’s MAXC ARB Skid Plate
Warn XD9000 Winch & Accessory Kit
Hi-Lift Jack & ARB Hi-Lift Jack Attachment Kit
Rear Bumper w/Swing-Away Spare Tire Carrier / Extraction Points / Hitch
(6) Warn ¾” 16K lb. Shackles
(3) 2” x 20’ Tow Ropes
(1) 4” x 30’ Tow Rope
ARMOR
2”x4” Extreme Off-Road Equipment Rock Sliders - http://www.nissan-offroad.com
Skid Row ‘Tellico Tough’ Full Belly Skid Plates – http://www.skidplates.com
LIGHTING
PIAA 1551XT Fog Lights
PIAA Superwhite Headlight Bulbs
IPF 960 Off-Road Lights Mounted on ARB
IPF 960 Off-Road Lights Mounted on Roof Light Bar
Utility Reverse Lights
OTHER STUFF
K&N Air Filter
CO2 Powertank
Optima 800U Red Top Battery
KargoMaster ‘Bushman’ Steel Safari Rack - http://www.kargomaster.com
Coolerman’s MAXC Clutch Interlock Bypass Kit
Trimmed Exhaust Pipe Back 6”
Radio Shack CB / Firestick 4’ Antenna
xterrabull
06-26-2001, 06:40 PM
Good thread idea: as you modify your truck, you can edit your "modifications" thread entry so it's like a "living document".
Cool; I like it.
Here's mine:
2000 NISSAN XTERRA Silver XE V6 4X4 M/T Utility/Power Packages
-aluminum alloys (Sport package wheels)
-factory tow hitch.
-Nissan cloth floor mats
-Front/back Nissan neoprene seat covers
SUSPENSION
-1” Torsion Bar Lift
-PowerBarz by Sway-A-Way Heavy Duty 27.48mm Torsion Bars
-31 X 10.5 R 15 Yokohama Geolander All Terrains
-Rancho RS9116 Shocks in Rear
-KYB Monomax PN 565045 in front
-Rancho Add-A-Leaf (replaced flat load leaf) Part# RS510 / P57022
-ARB Xterra Bull Bar
-Warn HS9500 Winch & Accessory Kit
ARMOR
-Nissan factory front splash guard ;):D:D:D
-Nissan factory rocker panel Rock-Crumplers (removed as needed) ;):D:D:D:D
LIGHTING
-PIAA 1551XT Fog Lights 55W=85W; 24,000 candlepower
-PIAA 80 PROXT driving lights 120W; 350,000 candlepower; mounted on ARB
-PIAA 910 driving lights 110W; 105,000 candlepower; custom mounted on aluminum angle bar with lights recessed in roof wind deflector (yes, I cut two holes in the damn air dam)
OTHER STUFF
-K&N Air Filter
-Optima 1050CA 830CCA Red Top Battery
-Weathertech front/back window wind deflectors
-Custom fabricated cabinet doors for rear cargo area storage bins making them actually useful (black ABS plastic, cabinet magnet latches, brushed aluminum handles, stainless steel hardware)
-Custom-cut cargo area/rear seat back protector (1/8" thick rubbery/plastic stuff with dimpled traction pattern)
-300W power inverter with outlet flush-mounted to front of center console storage area/arm rest
-6-circuit fuse block (slot type) in engine compartment for lights/accessories.
-3 position toggle switch for 3 modes of off road light operation: (1) completely disabled , (2) completely enabled, (3) enabled only when high beams are on (so, if high beams plus off road lights are on, turning off the high beams will also turn off the off road lights).
Schludwiller
06-26-2001, 08:06 PM
Hey T. How come you didn't put "took off my steprails" as a modification?
Oh, I had an idea for GoX. We should have everyone bring their steprails and we can build a monument in Ouray. Every year, new attendees can bring their steprails as a sacrifice.
rhombus
06-26-2001, 08:19 PM
2000 NISSAN XTERRA XE V6 4X4 3 Pack Yellow
Nissan Cargo Basket Net
SUSPENSION
1.5” Torsion Bar Lift
31 X 10.5x15 SSR's (Summer)
31x10.5x15 Winter Duelers (Winter)
6 Spoke 98 Pathfinder Aluminum Wheels (Summer)
Stock Steel Rims (Winter)
Rancho Steering Stabilizer
Bilstein Shocks (all around)- http://www.spencerlowracing.com
ARB Xterra Bull Bar
Warn XD9000 Winch w/85' MasterPull 3/8 line - http://www.masterpull.com
Nissan Tow Hitch
48" Hi-Lift Jack w/JackMate - http://www.jackmate.com
4000 lbs come-a-along
50' 3/8 MasterPull Winch Line Extension
(4) Warn ¾” 16K lb. Shackles
(1) 6" x 6' Tree Strap
(2) 2” x 20’ Tow Ropes
(1) 3” x 30’ Tow Rope
(1) 5' Chain
(1) 15' Chain
ARMOR
LIGHTING
Stock Fogs lights mounted under ARB
OTHER STUFF
ARB Air Comp mounted under hood
300w Inverter
K&N Air Filter
Optima Yellow Top Battery
Cobra 75 CB / Firestik 3’ Antenna - http://www.firestik.com
(3) FSR Radios
Emergency Kit (food, sleeping bag. candles, water etc...)
Aquamander
06-27-2001, 07:43 PM
I too haven't modified my X that much...
Denim Blue 4x4SE 3pk A/T
Ranchos all around
Interco Trxus M/T's 31x10.5
NisMo_Sway-away t-bars SLR 2"leaf shackles
Rancho Add a Leafs
EOE sliderz
Front anti-swaybar disconnects with stainless steel knobs.
K&N air filter
Manik tumbleweed deflector array holding my Hella's up (I know I know...)
ARB 10' tree strap
2"x 20 tow strap
4 big clevis,
1 20' length of PMI 7/16 static line
Craftsman mini tool case (under the seat)
2 FSR Motorola talkabouts (blue)
Magellan GPS315
H&K .40 USP Compact
More to come...
lemsip
06-27-2001, 08:41 PM
Surely the removal of side rails is far more worthy of a mention than the addition of nissan rubber mats ?
Synchro
06-27-2001, 09:42 PM
my guess is his list is of things he added, not took off.
lemsip
06-27-2001, 10:32 PM
I didnt mean to refer to anyone in particular I was thinking more of the hoards of 'look-at-my-X' web sites that list stickers and carpets as mods.
Removing steps and rear swaybar is free and it adds functionality.
xterrabull
06-27-2001, 10:41 PM
This is true; I think, however, people will tend to list things that involved a lot of one or more of the following: $$$, personal time & labor, creativity.
Synchro
06-27-2001, 10:55 PM
HEY NOW!!! those stickers and carpets are WAY F@#%ing cool man!!! don't talk about my carpets, i am very sensitive about them and you might break me. my X is out in the driveway right now....perched on a curb, posing for the envious neighbors. i think i am going to get SSRs, get an email like yourideme@yahoo.com, talk smack all day on the AC forums and give out bad information to everyone cause i am a know it all. or is this position already taken??? :bloated:
Schludwiller
06-28-2001, 01:43 AM
Suspension/Steering/Tires:
Bilstein shocks (SLR valved for ARB, and extended rears for shackles)
SLR 2" Leaf Shackles
Nismo Heavy Duty Torsion Bars
SLR Idler Arm Truss
SLR/Rancho Steering Stabilizer
31" Super Swamper SSR's on 15" Nissan steel wheels.
30" Pirelli Scorpion A/T's on 15" Pathfinder alloy wheels.
Armor/bumpers
ARB Navaro/Xterra front bumper
Custom rear bumper/swing away tire carrier.
Skid Row - 3 section belly skid plates.
Lighting
IPF SuperRally 960 Lights 130w bulbs.
PIAA 1500 XT Fogs
IPF 800 roof lights
IPF Reverse lights
PIAA SuperWhite replacement bulbs.
Recovery:
Warn XD9000 Winch
Warn front tow hook
D-rings welded to rear replacement bumper
Pro-Comp 3" 30' Tow-strap.
Warn Winch Accessories and bag.
48" Hi-lift Jack
Radio/GPS
Cobra 75WXST CB
Firestick II, Non-ground 3' Antenna
2 Motorola 250 FRS Radios.
Garmin StreetPilot GPS w/16m Ram.
Miscelaneous:
Nissan neoprene seat covers front and back
Nissan cargo protector
Nissan pet cage
Nissan rubber floor mats
Nissan gear basket net
KargoMaster Bushman with Hi-lift mount and custom light mounts.
ChuckH
06-28-2001, 06:22 AM
SLR 2" Leaf Shackles.
31" Pirelli Scorpion A/T's on 15" SE Alloys.
1-1/4 inch Torsion bar lift.
Rancho RSX shocks.
Armor/bumpers:
ARB Navaro/Xterra front bumper.
Lighting
Recovery:
What for? I never get stuck! Good thing too since my tow points are still an unfinished project!
Radio/GPS
Cobra 19 Ultra II CB.
Motorola T6310 FRS Radio.
Miscelaneous:
Nakamichi CD-45z CD/tuner
Nakamichi MB-70 6 disc in-dash CD changer.
2 Alpine amplifiers (under seats)
Diamond Audio HEX series seperates in front doors.
Boston Acoustics 6x9's in back.
IDQ 10" subwoofer in .73 cu. ft. enclosure.
Fire Extinguisher under front of driver's seat.
3 D cell maglite on shifter console.
Radio Shack inside/outside temperature guage.
Weathertech rubber mats.
K&N air filter.
2 Yakima Ankle Biter bike racks.
Misc. wrenches, sockets, air compressor, screwdrivers, etc.
PNWX stickers.
Type "R" sticker! :rolleyes:
warmonger
06-28-2001, 01:12 PM
Oww, I detect a note of hostility here! How would you like to be from Florida? Here the 2WD X's out number the 4WD X's at least 4 to 1.
But I also want everyone to keep one important thing in mind, how one modifies their X is directly determined by how they spend their time off-road.
Synchro, you guys are probably the best example. Here in Florida, we have no rocks. Therefore if you add skid plates, it traps mud and causes engine component overheating if not cleaned. A worst case scenario in Florida would be log crawling, not rock crawling. Also a low geared transfer case in Florida would only get you in trouble. Our two off-roading enviroments (mud and sand) both require hp and wheel speed/flotation. A 3.86/1 transfer case low range would not be suitable in those kinds of conditions.
Everybody has their own way of building trucks, some want them to suit a purpose and some just want looks. Although my truck looks stock at the moment, that will all end very shortly as I enter the next three phases of my build-up. But rock crawling for me is something I night do once a year at best, so my build-up has concentrated on those items for my most oft traveled off-road applications. I just wish we wouldn't bash those we disagree with. I may not agree with what somebody does to their truck, but it is their truck and they are welcome to do what they see fit. Whether it works or not is their problem, kno' whut I mean?
wqbang
06-28-2001, 01:48 PM
None
Armor/bumpers:
None
Lighting:
None
Recovery:
Tow Straps, Etc.
Radio/GPS:
Cobra 75WXST CB
K40 5' Fiberglass whip
Garmin eMap GPS w/8m Ram.
Miscelaneous:
KargoMaster Bushman Safari Rack
Wish List:
Super Swamper TrXus 31X10.50XR15
Bilsteins
EOE Rock Sliders
Rancho AAL
Synchro
06-28-2001, 01:59 PM
no questions asked you are correct. but what does this have to do with anything?? i was talking about one certain person who does not live in florida, not simple "anyone who fits any of the things i said." it is one person who meets all those and i am refering to. and this person started out by asking Vikram tons of questions and talking about outfitting his X like a poseur boy and trash talking and has continued down that track by becomeing further annoying than when he first started. so i state again, what does the way anyone builds out there truck no matter where they are from have to do with that one person and their stupidity??
and the first part about the carpets, stickers and pics in the driveway was making fun of many XOC folks.
Philosopher
06-28-2001, 02:56 PM
I was taking it for granted that mentioning I had EOE rock sliders would hint to people that I took my step rails off ...
:bonghitte
Mobycat
06-28-2001, 04:15 PM
:bonghitte
I took mine off....I don't have sliders.....yet....:D
warmonger
06-28-2001, 09:00 PM
I don't know of whom or what you speak, so I apologize if I offended you, it wasn't my intention. I just felt kind of lumped up because I frequent all three boards and it seemed kind of a generic hit. I generally let the shcmucks slide like water off a duck's back. If they want to be a know it all, we'll see how much they know when the next big gathering is. As you and I both know, talk is cheap. Who delivers the goods when necessary? I have seen your truck at work and there is no doubt there. But blow off the schmucks and party with the folks you like. That way you know you have somebody to help out when you need it.
Mobycat
06-28-2001, 09:22 PM
None
Armor/bumpers:
None
Lighting:
None
How ever do you get anywhere? No suspension, tires, lights and bumpers? Don't the cops bother you about that? :bloated:
Synchro
06-28-2001, 10:28 PM
please do not lump yourself into that group. god no! after seeing your work on your x and meeting you i have much respect for you. so don't think that. i don't think there is anyone on this board who should lump themselves into my comic poking fun at a particular group and more so a particular person. hmmmm....maybe i didn't segment out well enough in my post the 2 vastly different parties i was poking fun of. hmm....
i agree with you again, but it is just SOOOOO much fun, as most of the people on this board know first hand, making fun of some of these people. personally i think schlud should take a bow every once in a while as he makes me almost spit my mouthful of coke at the screen every so often while reading his comments. :D
wqbang
06-29-2001, 09:41 AM
Nope. I live in Alabama. :D
warmonger
06-29-2001, 09:52 PM
I guess it is time to list my mods, although most of you can access my website and learn far more about them than I can tell you here. But in spite of that, here they are:
Suspension:
1.5" front end lift via torsion bar adjustment
Driveline:
ARB Air Locker in rear
Custom built steering stabilizer system (Heckethorn shock) from early Pathfinder
Electrical:
Dual batteries with isolator
CB radio
4 100 watt Explorer Pro Comp off road driving lights
Custom electrical accessories setup with fuse block to power lights individually
Rewired headlights with Xenon 80/100 watt bulbs
Interior:
Added gauge cluster with voltmeter, air pressure gauge and switch to switch between main and auxillary batteries
Air compressor switch and air locker switch added to center console
Miscellaneous:
On-board air system with 3/4 hp BlowJax compressor with 2.5 gallon tank. Capable of running air tools, cycling air locker 33 times before compressor restart and airing up tires VERY quickly
Next on the list:
3" lift with front torsion bars and rear spring pack
Front ARB Air Locker
Super Swamper SSR 11.50/32 tires
I think that about covers it for now. Hopefully by the next time we hit Tellico again, it will really rock!
Philosopher
07-02-2001, 09:32 AM
Without a body lift, you'll be rubbing those SSR's. Just FYI.
