how do u adjust the headlights on a 93 deville ?Swifty420 01-31-2005, 07:23 PM my left headlight is jus shinein up in the dam sky ffs hardly any light is on that side but i can figure out how to adjust it :( kraigc 02-01-2005, 06:03 PM Have you made sure that the bulb itself has been installed straight into the assembly? To check (make it easy) there are 2 large screw fasteners right on top of the lamp assembly unscrew them both grab the entire lamp assembly and lift straight up the whole light will be loose, just enough so you can get your hands behind and to see if it is. Be carefull that you do not pull out the 2 optical lines that runs from the lamp to the marker lights on top of your fender. KC Automotive Network, Inc., Copyright ©2012
