Brake Lamp Warning Light is ON...nokeoi 03-14-2002, 11:16 PM How can I fix the "brake light warning light" . It is not the Brake light bulbs...they are ok...but Light in dash stays on all the time one brake light is not working. Thanks, Burford,Ontario speed-d3mon 03-16-2002, 10:49 AM if one brake light dosen't work the the light on the dash will always be on. i had this problem before. first i cleaned all the connectors but it didn't work. then i swapped out all my bulbs with new ones and the light went away. double check all the bulbs. and check your fuses brads94accord 03-16-2002, 10:51 AM do what speed-d3mon said and check all your bulbs again. one of the filaments could be burned out but the other still working. nokeoi 03-17-2002, 06:36 AM I got it fixed, bulbs were ok but seems some moisture is getting into the light fixture and is causing some problems with the wires. A wiggle here and there found the wire and fixed the problem but I may have to replace the wire harness soon. thanks for the replies guys. Larry Automotive Network, Inc., Copyright ©2012
