Inallgs kit install
strodda
03-14-2002, 08:43 PM
it shows a notch for the 2degree mark. am i supposed to line up the mark with the middle of the hole??
also if i install them myself, will an alignment pretty much fix all the possible little inaccuracies???
SweetAccord
03-16-2002, 02:05 AM
also if i install them myself, will an alignment pretty much fix all the possible little inaccuracies??? When my friends install it, the alignment was horrible. The toe was way off. I had to drive 30mph or less all the way to the alignment shop cuz it kept swirving out of nowhere....but that's my experience.
strodda
03-16-2002, 08:07 PM
will an alignment from any old shop fix it?? or you you have to goto some special aftermarket autoshop?
VTECseoul
03-17-2002, 02:25 AM
a shop that knows alignments would be best idea...pretty sure NTB or Sears knows how
SweetAccord
03-24-2002, 12:20 AM
will an alignment from any old shop fix it?? or you you have to goto some special aftermarket autoshop? Like VTECseoul said...NTB or Sears will fix it or somewhere that knows how to do alignments. I went to NTB to get mine aligned. I suggest to call around first before you take it in just in case they dont know how to do aftermarket camber kits. My friend had a bad experience at Sears, even when everything is still stock when he took it in. They didn't align his lude at all and took his money and didn't tell him anything at all!:mad:
*sorry about the late response
strodda
03-24-2002, 12:29 AM
ok thanks ill try sears. i called a custom shop and they quoted about $150 for the installation, and another 100 for the alignment. that sounded kind of high. but then ive also been told that if a shop does it at all, it could cost more to align lowered suspensions.
1more thing, whats ntb?? i live in the bay area, CA. and ive never heard of it.
SweetAccord
03-24-2002, 11:28 PM
1more thing, whats ntb?? i live in the bay area, CA. and ive never heard of it. NTB=National Tire & Battery. Go to www.NTB.com and see if there is a store in your area.
Really, they charge you more for lowered suspensions? Mine was $55, and they didn't charge me extra. I think alignments anyway is around $50.
Is the $150 installation for just the camber kits?
hondaman-iac
03-25-2002, 02:20 PM
they shouldn't charge you more for a lowered car. basically it is the same thing as a stock suspension.
strodda
03-26-2002, 01:45 AM
well theres no ntb within 100miles of me. what are some other shops that are good for gettin alignments at??
is there a certain type of machine used for aligning a car with an adjustable camber kit?? i asked midas when i went there to get the lca bolt welded, and they said the alignment machine they had was old and wouldnt work, or work well, for my car with an altered suspension.
also... when they check the alignment, do they go in and adjust the camber kit if necessary?
and one more thing:D do i just need to guess on the rear correction?? since i dont think the shop will take it apart and add more washers if needed while checking alignment.
