best ATF for tcase?mx52nv 01-31-2005, 02:48 PM was just curious which brand and weight I should use in the tcase when I change the fluid this week? also thinking of changing the tranny fluid. gtmud 02-01-2005, 02:41 PM Regular dextron/mercrom III is good, but suggest the Mobile one synthetic tranny fluid for the T-case. HOwever the tranny, use ONLY ATF3! I guess it doesn't like D/M III. Acorrding to the dealer. JDPascal 02-01-2005, 03:23 PM I will second gtmud's recommendation for the transfer case fluid. Mobil 1 ATF is an excellent choice as is the Amsoil equivilent. For the tranny, my preference is the ATF +4 that is made for the newer transmissions. You can change up to the +4 from the + 3 but you can't go back. The +4 has made a bigh difference in how my 96 5.2 shifts in the cold weather. If you are going to change the tranny fluid, how long since the bands were adjusted. One of the bands is only adjusted from inside the pan. Be sure and follow the procedure and specs for your transmission exactly if you do attempt it. JD Myrtle Beach 02-01-2005, 04:26 PM i agree with both, The ATF +4 is synthetic which I would recomend Amsoil.. If not mobil or an equilvalent should work well Automotive Network, Inc., Copyright ©2012
