93 probe gt stalling problems
75monte
01-31-2005, 12:33 PM
a friend of mine has a 93 probe gt with the 2.5 and it has bout 145,000 on it. It would run for about 45 minutes, sometimes not even that long, then just die. it would start up after setting for about 20 minutes. we just put new plugs, pcv, and fuel filter on it and it did not help. the fuel filter wasnt clogged at all either. after it died we ran the codes and no codes came up. if anyone can help it would be great we are stuck pretty bad. thank you
a1waytrip
01-31-2005, 03:58 PM
maybe it's the distributer, i had same problem, it was the distributer, it's a pain in the @$$. but some codes should be stored in the comp... im not sure good luck
Canada 93 Mazda626
02-22-2005, 02:01 AM
I am also having ignitor problems and have found this link in my search for the truth. I knew the dealer was trying to job me when they told me $825 to fix it. $20 ignitor replacement!!
http://forums.probetalk.com/showthread.php?t=1701081990
75monte
02-22-2005, 09:11 AM
it was the whole distributor, after it would die we wouldnt get any spark and after running for bout 5 minutes the distributor would be so hot u couldnt touch it. we replaced that ($275) and it runs perfect now.
a1waytrip
02-24-2005, 01:26 AM
good luck, i'm about to transfer to my 3rd remanufactured pos distributer. keep your receit. and pray it's covered under warenty, cause there is a really good chance it is going to go bad on you again. oh that msd mod is a pretty good deal, but there is some alot of talk about it. some good, some bad, get some more info on it, im in the process of looking into it too. let me know if you do it, and if it turns out to work pretty good
-tom
