Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Caprice
Old 01-30-2005, 10:20 PM   #1
tink21
tink21 Normal reputation
how do i change a carburetor on an 84' chevy caprice classic
I have a 1984 Chevy Caprice Station Wagon and I don't know how to change the carburetor. Any ideas? I really need to change it before my long drive.
tink21 is offline   Reply With Quote
Old 01-30-2005, 11:10 PM   #2
PeteA216
PeteA216's Avatar
PeteA216 Normal reputation
Send a message via AIM to PeteA216
Re: how do i change a carburetor on an 84' chevy caprice classic
You want to replace the entire carburetor? Its cheaper to rebuild, but if you want to replace it its very easy. First, remove the accelerator cable on the driver's side of the carb. There should be a small spring loaded clip holding it in (this is how it is on mine). Remove all black rubber vaccume hoses, taking note of where each was placed. Pull off the two electronic plugs on the front of the carb and the wire to the electric choke. Then, unscrew the fuel return on the back of the carb (metal line). Then, very carefully, not to stip anything, while using another wrench to hold the fuel filter case, unscrew the fuel line on the front of the carb. Fuel will spill out, just be sure not to be smoking. Then, remove the four screws on the base of the carb, and slowly and carefully lift the carburetor off the engine, being sure not to let anything fall into the intake manifold. Replace the gasket if needed. Then when putting the new carb on, be sure everything gets hooked back up, and don't crank down too hard on the fuel line. Just take your time, and be sure to take note of where everything was hooked up to. If you're nervous, use a digital camera to help you by taking pictures of everything. Good luck!
PeteA216 is offline   Reply With Quote
Old 02-01-2005, 02:03 AM   #3
tink21
Re: Re: how do i change a carburetor on an 84' chevy caprice classic
Thank you for your help. I couldn't find the info anywhere else. I'm having a friend do this for me because i already have the rebuilt carburater from Autozone. Again, I appreciate this. Thanks.
Bookmarks
Google
Web AF
