1995 325I overheatingbodjie2001 01-30-2005, 08:42 PM I have posted the same problem last month. I replaced WATER PUMP, THERMOSTAT, Radiator Hoses and 2 drivebelts but my car still overheats. Someone suggested that it's the Cylinder Head Gasket. I replaced the Cylinder Head Gasket but didnot fix the problem. My car overheats just after 15 minutes. There's water bubling out from the coolant bleeder and there's no hot air coming out when I turn on the heater. Also, I don't see any coolant leak but the coolant will be gone after I turned off the engine. Anyone with the same problem? bimmerman333 02-01-2005, 09:17 PM there was a recall from bmw on the 92 to 99 for the thermostats on the 3 series i had mine replaced free of charge at bmw. could be the problem. good luck! Axelpkt 02-01-2005, 09:24 PM try the fan clutch, my friends 94 325 would overheat like that and thats what it ended up being Mark E M 02-02-2005, 06:43 PM A 95' 325 i, dosen't that have an electric fan on the radiator?? Mark. Axelpkt 02-02-2005, 09:48 PM A 95' 325 i, dosen't that have an electric fan on the radiator?? Mark. it might but it still has a fan clutch vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
