Problems Starting 90 Cherokeechili 01-30-2005, 03:41 PM OK having major problems with my 1990 Cherokee 4.0l I-6 4x4. Drove the jeep to the store this morniing no problems.....got home had breakfast was gonna run to the vid store, hopped in and NOTHING! No lights buzzers radio etc.... Checked my voltage at the battery gettting 12.7v......noticed the pos terminal was a tad loose.....tightned and cleaned up....still nothing.... NOW WHAT? :banghead: Chili JDPascal 01-30-2005, 03:48 PM Did you clean up the neg post/clamp too??? JD chili 01-30-2005, 05:27 PM Did you clean up the neg post/clamp too??? JD Yup sure did......now for the REALLY wierd part......let it sit for about 45 mins after messing with it went in hit the key and it fired right up...... Go figure..... Maybe I need to get a young preist and and old preist to exercise my deamons from it :werd: JDPascal 01-30-2005, 10:59 PM WELL..............IF both battery posts and the inside of the cable clamps are shiney clean and tight, I'd have the battery tested. Where you didn't have lites or radio or other accessories, those battery posts/clamps/cables are the first most likely causes. If it was the switch or the starter relay in the PDC, you should still have lites. JD Automotive Network, Inc., Copyright ©2012
